Ga door naar hoofdinhoud
HTC One Max Rear Facing Camera Replacement
Wat je nodig hebt
  1. HTC One Max Rear Facing Camera Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Rear Facing Camera Replacement: stap 2, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Rear Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    The orange circle in line with the 4 other red circles down the RH side (as shown) in the photo should be red also, as this shows a screw, not the cable (which is by the volume buttons).
    Huey Smith - Antwoord
    Hey Huey,
    Nice catch! This has now been fixed.
    Geoff Wacker -
  4. HTC One Max Rear Facing Camera Replacement: stap 4, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: stap 5, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: stap 5, afbeelding 2 van 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Rear Facing Camera Replacement, Motherboard: stap 6, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Rear Facing Camera Replacement: stap 7, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    Where can i find a replacemt ir blaster?
    yuuki1942 - Antwoord
  8. HTC One Max Rear Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Rear Facing Camera Replacement: stap 9, afbeelding 1 van 3 HTC One Max Rear Facing Camera Replacement: stap 9, afbeelding 2 van 3 HTC One Max Rear Facing Camera Replacement: stap 9, afbeelding 3 van 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Rear Facing Camera Replacement: stap 10, afbeelding 1 van 3 HTC One Max Rear Facing Camera Replacement: stap 10, afbeelding 2 van 3 HTC One Max Rear Facing Camera Replacement: stap 10, afbeelding 3 van 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    What does the orange circle refer to, as the text is a duplicate of the red circle description (and the highlighted item isn't connected with the three gate connectors)?
    I think the orange circle refers to a 4th gate connector which needs to be disconnected.
  11. HTC One Max Rear Facing Camera Replacement: stap 11, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Rear Facing Camera Replacement, IR Blaster: stap 12, afbeelding 1 van 1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  13. HTC One Max Rear Facing Camera Replacement: stap 13, afbeelding 1 van 1
    • Pick up and set aside vibrator, do not disconnect.
  14. HTC One Max Rear Facing Camera Replacement: stap 14, afbeelding 1 van 1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    the orange circle pointed at ribbon cable while the red pointed at infrared sensor
    mohamedeldeeb69 - Antwoord
  15. HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: stap 15, afbeelding 1 van 2 HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: stap 15, afbeelding 2 van 2
    • Lift the secondary motherboard with the camera attached.
  16. HTC One Max Rear Facing Camera Replacement: stap 16, afbeelding 1 van 3 HTC One Max Rear Facing Camera Replacement: stap 16, afbeelding 2 van 3 HTC One Max Rear Facing Camera Replacement: stap 16, afbeelding 3 van 3
    • Use a plastic opening tool to disconnect the camera ribbon cable.
    • Remove rear camera.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Andrew Keller
1.131 Reputatie
5 handleidingen geschreven
USF Tampa, Team 11-3, Blackwell Fall 2014 Lid van USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Leden
7 handleidingen geschreven
Één opmerking
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 8,039
