Ga door naar hoofdinhoud
HTC Maple 100 Motherboard Replacement
Wat je nodig hebt
  1. HTC Maple 100 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Motherboard Replacement: stap 3, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Motherboard Replacement, Back Panel: stap 4, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Motherboard Replacement: stap 6, afbeelding 1 van 3 HTC Maple 100 Motherboard Replacement: stap 6, afbeelding 2 van 3 HTC Maple 100 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Motherboard Replacement: stap 8, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Motherboard Replacement: stap 9, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Motherboard Replacement: stap 10, afbeelding 1 van 3 HTC Maple 100 Motherboard Replacement: stap 10, afbeelding 2 van 3 HTC Maple 100 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Motherboard Replacement: stap 11, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Motherboard Replacement: stap 12, afbeelding 1 van 2 HTC Maple 100 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Gently pull on the ribbon cable to separate the motherboard.
Conclusie
Andrew Van Meter
24 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-29, Maness Fall 2011 Lid van Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,074
