Inleiding
Remove 4 Torx screws and 2 #00 Philps
  1. First remove the back cover of your phone to expose the battery.
    • First remove the back cover of your phone to expose the battery.
  2. Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
    • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
    • Take the battery out
    • When reassembling, make sure that the battery contacts match up.
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
    • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
    • Use the plastic opening tool to pry the clips off
    • Insert the plastic opening tool along the seams at different points to it pry up
    • This may require a bit of force. The USB port cover may fall off in this step.
Conclusie
Andrew Van Meter
24 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-29, Maness Fall 2011 Lid van Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Leden
9 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 708
