Ga door naar hoofdinhoud
HTC Magic Speaker Replacement
Wat je nodig hebt
  1. HTC Magic Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 HTC Magic Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 HTC Magic Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. HTC Magic Speaker Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. HTC Magic Speaker Replacement: stap 3, afbeelding 1 van 2 HTC Magic Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  4. HTC Magic Speaker Replacement: stap 5, afbeelding 1 van 2 HTC Magic Speaker Replacement: stap 5, afbeelding 2 van 2
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
Conclusie
LucasJV
735 Reputatie
3 handleidingen geschreven
Verheij.co Lid van Verheij.co
Business
1 Lid
5 handleidingen geschreven
Één opmerking
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 10,698
