Ga door naar hoofdinhoud
HTC Hero Trackball Replacement
Wat je nodig hebt
  1. HTC Hero Trackball Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Trackball Replacement: stap 2, afbeelding 1 van 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Trackball Replacement: stap 3, afbeelding 1 van 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Trackball Replacement: stap 4, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 4, afbeelding 2 van 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Trackball Replacement, Trackball: stap 5, afbeelding 1 van 2 HTC Hero Trackball Replacement, Trackball: stap 5, afbeelding 2 van 2
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
  6. HTC Hero Trackball Replacement: stap 6, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 6, afbeelding 2 van 2
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
  7. HTC Hero Trackball Replacement: stap 7, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 7, afbeelding 2 van 2
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
  8. HTC Hero Trackball Replacement: stap 8, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 8, afbeelding 2 van 2
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
  9. HTC Hero Trackball Replacement: stap 9, afbeelding 1 van 3 HTC Hero Trackball Replacement: stap 9, afbeelding 2 van 3 HTC Hero Trackball Replacement: stap 9, afbeelding 3 van 3
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Max Brown
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-26, Amido Winter 2012 Lid van Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 1,520
