Ga door naar hoofdinhoud
HTC Hero Camera Replacement
Wat je nodig hebt
  1. HTC Hero Camera Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC Hero Camera Replacement: stap 2, afbeelding 1 van 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC Hero Camera Replacement: stap 3, afbeelding 1 van 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC Hero Camera Replacement: stap 4, afbeelding 1 van 2 HTC Hero Camera Replacement: stap 4, afbeelding 2 van 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC Hero Camera Replacement, Camera: stap 5, afbeelding 1 van 3 HTC Hero Camera Replacement, Camera: stap 5, afbeelding 2 van 3 HTC Hero Camera Replacement, Camera: stap 5, afbeelding 3 van 3
    • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC Hero Camera Replacement: stap 6, afbeelding 1 van 2 HTC Hero Camera Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC Hero Camera Replacement: stap 7, afbeelding 1 van 2 HTC Hero Camera Replacement: stap 7, afbeelding 2 van 2
    • Pull the released camera enclosure away from the motherboard until it is completely free.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC Hero Camera Replacement: stap 8, afbeelding 1 van 2 HTC Hero Camera Replacement: stap 8, afbeelding 2 van 2
    • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Max Brown
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-26, Amido Winter 2012 Lid van Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 40
Altijd: 1,703
