Ga door naar hoofdinhoud
HTC HD2 Vibrator Replacement
Wat je nodig hebt
  1. HTC HD2 Vibrator Replacement, Battery: stap 1, afbeelding 1 van 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Vibrator Replacement: stap 2, afbeelding 1 van 2 HTC HD2 Vibrator Replacement: stap 2, afbeelding 2 van 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Vibrator Replacement, Midframe: stap 3, afbeelding 1 van 2 HTC HD2 Vibrator Replacement, Midframe: stap 3, afbeelding 2 van 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Vibrator Replacement: stap 4, afbeelding 1 van 2 HTC HD2 Vibrator Replacement: stap 4, afbeelding 2 van 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Vibrator Replacement, Vibrator: stap 5, afbeelding 1 van 2 HTC HD2 Vibrator Replacement, Vibrator: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Set the phone down on its screen.
    • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
  6. HTC HD2 Vibrator Replacement: stap 6, afbeelding 1 van 1
    • Pull the vibrator motor from the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Puchalski
813 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-55, Amido Spring 2011 Lid van Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 5,902
