Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Lay the phone down on it's screen.
Lift up on the lip and pull the battery from the phone.
Remove the four black 3.5mm T5 screws from the back of the phone.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
The speaker should be easily popped out of place with a small amount of force
Congratulations! The speaker is now removed and can be replaced or repaired.
Één andere persoon heeft deze handleiding voltooid.
