Inleiding
Use this guide to replace the earpiece speaker in the HTC HD2. This is a fairly easy repair, once the rear cover is removed.
Wat je nodig hebt
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
Disconnect the small speaker cable from its socket on the motherboard.
Remove the earpiece speaker from the phone.
Één andere persoon heeft deze handleiding voltooid.
