Ga door naar hoofdinhoud
HTC Flyer Back Cover Replacement
Wat je nodig hebt
  1. HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 3 HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 3 HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Back Cover Replacement: stap 2, afbeelding 1 van 3 HTC Flyer Back Cover Replacement: stap 2, afbeelding 2 van 3 HTC Flyer Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Back Cover Replacement: stap 3, afbeelding 1 van 3 HTC Flyer Back Cover Replacement: stap 3, afbeelding 2 van 3 HTC Flyer Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Back Cover Replacement: stap 4, afbeelding 1 van 2 HTC Flyer Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
Conclusie
Justin Funk
473 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-5, Leahy Fall 2014 Lid van USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 394
