Ga door naar hoofdinhoud
HTC Evo 3D Speaker Replacement
Wat je nodig hebt
  1. HTC Evo 3D Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 HTC Evo 3D Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 HTC Evo 3D Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Speaker Replacement: stap 2, afbeelding 1 van 2 HTC Evo 3D Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by pulling down on the bottom of the card.
  3. HTC Evo 3D Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the four T5 screws using the cooresponding screwdriver.
    • Remove the two J000 screws using the cooresponding screwdriver.
  4. HTC Evo 3D Speaker Replacement: stap 4, afbeelding 1 van 2 HTC Evo 3D Speaker Replacement: stap 4, afbeelding 2 van 2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • The marked part in the second photo is the speaker.
  5. HTC Evo 3D Speaker Replacement: stap 5, afbeelding 1 van 3 HTC Evo 3D Speaker Replacement: stap 5, afbeelding 2 van 3 HTC Evo 3D Speaker Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • The speaker can be loosened from its glue with the spudger.
    • Pry from the bottom with constant pressure to loosen one end of the speaker.
    • When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
  6. HTC Evo 3D Speaker Replacement: stap 6, afbeelding 1 van 1
    • With the old speaker removed, insert the new speaker in the same place.
    • When reinserting the new speaker, be sure that the golden contacts (As previously marked) are facing up.
Conclusie
To reassemble your device, follow these instructions in reverse order but with a new speaker.
Één andere persoon heeft deze handleiding voltooid.
James Burke
245 Reputatie
2 handleidingen geschreven
USF Tampa, Team 14-20, Meier Fall 2015 Lid van USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 347
