Ga door naar hoofdinhoud
HTC EVO Design 4G Charging Port Replacement
Wat je nodig hebt
  1. HTC EVO Design 4G Charging Port Replacement, Screen: stap 1, afbeelding 1 van 1
    • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
  2. HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 2, afbeelding 1 van 1
    • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  3. HTC EVO Design 4G Charging Port Replacement, Removing Battery: stap 3, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Removing Battery: stap 3, afbeelding 2 van 2
    • When open, pull on “Open” tab and it should rotate towards you
    • Grab the bottom edge of the battery and pull it toward you
  4. HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 4, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 4, afbeelding 2 van 2
    • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
    • Info*: The adhesive tape that you may find will not be necessary for replacement later
  5. HTC EVO Design 4G Charging Port Replacement, Removing Screws: stap 5, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Removing Screws: stap 5, afbeelding 2 van 2
    • Remove the two Phillips screws to release the casing above the port
    • Remove the top and bottom pairs of Torx screws.
    • Remove the middle pair of two Phillips screws.
  6. HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 6, afbeelding 1 van 3 HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 6, afbeelding 2 van 3 HTC EVO Design 4G Charging Port Replacement, Removing Casing: stap 6, afbeelding 3 van 3
    • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
  7. HTC EVO Design 4G Charging Port Replacement, Removing Screws Continued: stap 7, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Removing Screws Continued: stap 7, afbeelding 2 van 2
    • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
  8. HTC EVO Design 4G Charging Port Replacement, Removing Rear Housing: stap 8, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Removing Rear Housing: stap 8, afbeelding 2 van 2
    • Remove the rear housing by prying around the edge with your Safety Pry Tool
  9. HTC EVO Design 4G Charging Port Replacement, Pull the Plug: stap 9, afbeelding 1 van 1
    • Unplug the wire connecting the vibrator to the board with your tweezers
  10. HTC EVO Design 4G Charging Port Replacement, Like a Book: stap 10, afbeelding 1 van 1
    • Unfold motherboard from the screen (open carefully like a book)
  11. HTC EVO Design 4G Charging Port Replacement, Flex Cables: stap 11, afbeelding 1 van 1
    • Disconnect the two aluminum flex cables
  12. HTC EVO Design 4G Charging Port Replacement, Broken Bond: stap 12, afbeelding 1 van 1
    • The flex cables should be the only binding and after being removed should leave you with the separate screen
  13. HTC EVO Design 4G Charging Port Replacement, Charging Port: stap 13, afbeelding 1 van 2 HTC EVO Design 4G Charging Port Replacement, Charging Port: stap 13, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Desoldering Pump
    $3.99
    Koop
    • Use solder sucker to remove solder from the back of charging port
    • Use solder sucker to remove solder from the front of charging port
    • There are 2 soldering locations from the top view and 4 locations from the bottom view
    • Refer to the How To Solder and Desolder Connections guide if needed.
    • Solder sucker will be very hot
Conclusie
Lilian Nguyen
208 Reputatie
2 handleidingen geschreven
IUPUI, Team S3-G2, Harley Spring 2017 Lid van IUPUI, Team S3-G2, Harley Spring 2017
IUPUI-HARLEY-S17S3G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 414
