Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
  1. Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
    • Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
  2. Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it
    • Use your safety pry tool on the outside edges of the back casing to lift and remove it
  3. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  4. Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
    • Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
  5. Remove old lens. Place replacement lens over the camera lens and it should loosely snap on
    • Remove old lens.
    • Place replacement lens over the camera lens and it should loosely snap on
    • Info*: Don’t worry if the cover is loose because the cover of the phone would hold it in place
  6. Snap the cover back into place
    • Snap the cover back into place
Eindstreep
Victoria
94 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G4
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 269
