Ga door naar hoofdinhoud
HTC Droid Incredible MicroSD card Replacement
  1. HTC Droid Incredible MicroSD card Replacement, Battery: stap 1, afbeelding 1 van 3 HTC Droid Incredible MicroSD card Replacement, Battery: stap 1, afbeelding 2 van 3 HTC Droid Incredible MicroSD card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible MicroSD card Replacement: stap 2, afbeelding 1 van 1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible MicroSD card Replacement: stap 3, afbeelding 1 van 3 HTC Droid Incredible MicroSD card Replacement: stap 3, afbeelding 2 van 3 HTC Droid Incredible MicroSD card Replacement: stap 3, afbeelding 3 van 3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible MicroSD card Replacement, MicroSD card: stap 4, afbeelding 1 van 2 HTC Droid Incredible MicroSD card Replacement, MicroSD card: stap 4, afbeelding 2 van 2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible MicroSD card Replacement: stap 5, afbeelding 1 van 2 HTC Droid Incredible MicroSD card Replacement: stap 5, afbeelding 2 van 2
    • Pull the MicroSD card straight out of its slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Optimus Goldheart
502.852 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,095
