Inleiding
In addition to the possibility that the battery may be the reason why your phone is not charging, the charging port may also need to be replaced or tightened if loose. Ensure that the delicate parts of the phone revealed in the replacement procedure.
Onderdelen
Geen onderdelen nodig.
  1. Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
    • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
  2. Remove the battery after taking off the cover.
    • Remove the battery after taking off the cover.
  3. Remove eight 4mm and one 5mm Torx screws.
    • Remove eight 4mm and one 5mm Torx screws.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Use a prying tool to pry off the midframe. Use a prying tool to pry off the midframe.
    • Use a prying tool to pry off the midframe.
  6. Remove the 4mm Torx screw holding the charging port to the phone.
    • Remove the 4mm Torx screw holding the charging port to the phone.
  7. Remove the silver bracket holding the charging port in place.
    • Remove the silver bracket holding the charging port in place.
  8. Use a prying tool to remove the charging port as shown.
    • Use a prying tool to remove the charging port as shown.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tevin
639 Reputatie
4 handleidingen geschreven
USF Tampa, Team 15-1, Remmell Fall 2014 Lid van USF Tampa, Team 15-1, Remmell Fall 2014
USFT-REMMELL-F14S15G1
4 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 4
Altijd: 623
