Inleiding
Replacing the Droid Eris Digitizer or LCD Screen is a straightforward process that is easy to do within a short period of time.
Created by Liam Tidwell of LiamTek
Wat je nodig hebt
Turn off your HTC Droid Eris.
Remove the back cover, battery, and memory card (if installed).
Remove the Philips screws circled in red. Be careful with the moisture indicator (indicated by the blue rectangle).
Be sure to move the connectors out of the way. (One connector extends across the main board, so be careful the connector does not snag.)
Carefully remove the mainboard and set it aside.
Carefully separate the face of the phone from the LCD screen by using a spudger or a pry pick.
Replace the broken LCD or digitizer and reassemble in reverse.
If replacing the digitizer, you may either replace the entire front as part of an assembly or use a heat gun to separate and replace the glass only.
Één andere persoon heeft deze handleiding voltooid.
