Inleiding
This guide will outline how to disassemble the logic board of the HTC Desire V smartphone for replacement.
Wat je nodig hebt
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
Unplug the vibration motor shown from the white plug on the motherboard.
You will probably need tweezers to do this.
Remove the black information sticker if this is the first time opening the handset.
You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
For this you may wish to use a spudger or tweezers.
Noting that the rear side of the black ribbon cable is gold, use a spudger or an opening tool to gently disconnect it from the motherboard by levering it up at the right side
Één andere persoon heeft deze handleiding voltooid.
