Ga door naar hoofdinhoud
HTC Desire 826 Headphone Jack Replacement
Wat je nodig hebt
  1. HTC Desire 826 Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 3 HTC Desire 826 Headphone Jack Replacement, Battery: stap 1, afbeelding 2 van 3 HTC Desire 826 Headphone Jack Replacement, Battery: stap 1, afbeelding 3 van 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Headphone Jack Replacement: stap 2, afbeelding 1 van 3 HTC Desire 826 Headphone Jack Replacement: stap 2, afbeelding 2 van 3 HTC Desire 826 Headphone Jack Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Headphone Jack Replacement: stap 4, afbeelding 1 van 2 HTC Desire 826 Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Headphone Jack Replacement, Headphone Jack: stap 5, afbeelding 1 van 3 HTC Desire 826 Headphone Jack Replacement, Headphone Jack: stap 5, afbeelding 2 van 3 HTC Desire 826 Headphone Jack Replacement, Headphone Jack: stap 5, afbeelding 3 van 3
    • Use the T5 screwdriver to remove the three 4.00 mm screws as shown.
    • Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
  6. HTC Desire 826 Headphone Jack Replacement: stap 6, afbeelding 1 van 2 HTC Desire 826 Headphone Jack Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two 4.00 mm screws attaching the bottom plastic panel using a T5 screwdriver.
    • Using the spudger, remove the bottom plastic piece.
  7. HTC Desire 826 Headphone Jack Replacement: stap 7, afbeelding 1 van 3 HTC Desire 826 Headphone Jack Replacement: stap 7, afbeelding 2 van 3 HTC Desire 826 Headphone Jack Replacement: stap 7, afbeelding 3 van 3
    Koop
    • Using the spudger, remove the bottom part of the motherboard.
    • Using the angled tweezers, disconnect the headphone jack from the motherboard.
    • Using the plastic spudger, pop out the circular silver piece and lift the top part of the motherboard.
  8. HTC Desire 826 Headphone Jack Replacement: stap 8, afbeelding 1 van 2 HTC Desire 826 Headphone Jack Replacement: stap 8, afbeelding 2 van 2
    • Using the angled tweezers, pop off the metal piece on top of the headphone jack.
    • Using the angled tweezers, remove the headphone jack.
Conclusie
Payton Rawson
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 173
