Ga door naar hoofdinhoud
HTC Desire 816 Top Speaker Replacement
Wat je nodig hebt
  1. HTC Desire 816 Top Speaker Replacement, Top Speaker: stap 1, afbeelding 1 van 1
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. HTC Desire 816 Top Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. HTC Desire 816 Top Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. HTC Desire 816 Top Speaker Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. HTC Desire 816 Top Speaker Replacement: stap 5, afbeelding 1 van 1
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. HTC Desire 816 Top Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Edward Garcia
527 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-3, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 1,279
