Inleiding
The rear panel of the phone is responsible for keeping all of the device's hardware safe and secure. It is secured by eight 8.3 mm Torx head screws, and is accessible by first removing the back cover and battery. If the rear panel is damaged, it should be removed and replaced as a damaged panel can lead to damage of other internal hardware.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Één andere persoon heeft deze handleiding voltooid.
