Inleiding
Check to see if the indicator light at the top of the phone illuminates when plugged in. If the indicator light illuminates, the battery is likely at fault as it can no longer hold a charge (if this is the case, see the guide for battery replacement). If the indicator light does not illuminate when plugged in, the charging port may be faulty. The charging port, or printed circuit board (PCB board), can be replaced if the device if it is no longer responsive when plugged in.
  1. Use the spudger to pry the back cover off.
    • Use the spudger to pry the back cover off.
  2. Use  spudger tool to pry under the battery to lift it up and out.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove eight 8.3mm T4  screws with the  Torx screwdriver.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  5. Pry the back panel of the screen using the plastic opener.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  6. Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  7. Using the plastic prying tool, pry the PCB device from the screen of the phone.
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
Conclusie
Steven Pate
191 Reputatie
7 handleidingen geschreven
USF Tampa, Team 9-3, Blackwell Fall 2014 Lid van USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 15
Altijd: 1,676
