Ga door naar hoofdinhoud
HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement
Wat je nodig hebt
  1. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Removing Battery: stap 2, afbeelding 1 van 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Remove 8 Torx Screws: stap 3, afbeelding 1 van 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Prying Off Rear Panel: stap 4, afbeelding 1 van 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): stap 5, afbeelding 1 van 1
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
Conclusie
Steven Pate
191 Reputatie
7 handleidingen geschreven
USF Tampa, Team 9-3, Blackwell Fall 2014 Lid van USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,067
