Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use spudger tool to pry under the battery to lift it up and out.
Remove eight 8.3mm T4 screws with the Torx screwdriver.
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
Using the plastic prying tool, pry the PCB device from the screen of the phone.
Using the spudger, pry the speaker away from the screen.
3 andere personen hebben deze handleiding voltooid.
