Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
First, it is necessary to ensure that the bottom speaker is faulty before replacement. Confirm that this is the case by testing it via a phone call followed by testing the microphone recording application on the phone. If the speaker does not work in both of these cases, it is likely damaged and in need of replacement. The procedure will be presented step-wise to ensure that none of the hardware is damaged, as this guide involves the removal of fragile components.
  1. Use the spudger to pry the back cover off.
    • Use the spudger to pry the back cover off.
  2. Use  spudger tool to pry under the battery to lift it up and out.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. Remove eight 8.3mm T4  screws with the  Torx screwdriver.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Pry the back panel of the screen using the plastic opener.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  6. Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  7. Using the plastic prying tool, pry the PCB device from the screen of the phone.
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  8. Using the spudger, pry the speaker away from the screen.
    • Using the spudger, pry the speaker away from the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Steven Pate
191 Reputatie
7 handleidingen geschreven
USF Tampa, Team 9-3, Blackwell Fall 2014 Lid van USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Leden
Één commentaar
Mobile spekar
siv kumar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 813
