Ga door naar hoofdinhoud
HTC Desire 700 Dual Sim Bottom Speaker Replacement
Wat je nodig hebt
  1. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Removing Battery: stap 2, afbeelding 1 van 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Remove 8 Torx Screws: stap 3, afbeelding 1 van 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Prying Off Rear Panel: stap 4, afbeelding 1 van 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Printed Circuit Board (PCB): stap 5, afbeelding 1 van 1
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Bottom Speaker Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  7. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Bottom Speaker: stap 7, afbeelding 1 van 1
    • Using the spudger, pry the speaker away from the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Steven Pate
191 Reputatie
7 handleidingen geschreven
USF Tampa, Team 9-3, Blackwell Fall 2014 Lid van USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Leden
14 handleidingen geschreven
Één opmerking
Mobile spekar
siv kumar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 869
