Inleiding
This guide discusses how to replace the Charging Port and some other parts on the HTC Desire 626 by using some steps.
Wat je nodig hebt
Insert plastic opening tool in between the back cover and grey plastic.
Gently work your way around the phone while sliding the tool.
Gently pry on plastic cover as needed to release fasteners.
Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Één andere persoon heeft deze handleiding voltooid.
