Ga door naar hoofdinhoud
HTC Desire 626s Backplate Replacement
Wat je nodig hebt
  1. HTC Desire 626s Backplate Replacement, Backplate: stap 1, afbeelding 1 van 3 HTC Desire 626s Backplate Replacement, Backplate: stap 1, afbeelding 2 van 3 HTC Desire 626s Backplate Replacement, Backplate: stap 1, afbeelding 3 van 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: stap 2, afbeelding 1 van 2 HTC Desire 626s Backplate Replacement: stap 2, afbeelding 2 van 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: stap 3, afbeelding 1 van 2 HTC Desire 626s Backplate Replacement: stap 3, afbeelding 2 van 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 264
