Ga door naar hoofdinhoud
HTC Desire 626 Battery Replacement
Wat je nodig hebt
  1. HTC Desire 626 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert an opening pick between the back cover and chassis, and pry around the perimeter until the back cover releases.
    • Remove the back cover.
  2. HTC Desire 626 Battery Replacement: stap 2, afbeelding 1 van 2 HTC Desire 626 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the "void" sticker over the screw near the top-right of the battery, and the larger one near bottom of the battery.
    • Don't worry about voiding warranties; those stickers are illegal in the US!
    • Use a Torx T5 screwdriver to remove the six screws.
    • Use a Phillips #000 screwdriver to remove the two screws.
  3. HTC Desire 626 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the white plastic frame with the opening tool.
  4. HTC Desire 626 Battery Replacement: stap 4, afbeelding 1 van 2 HTC Desire 626 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use an ESD safe tool to carefully "walk" the battery connector out of its port.
    • Use an opening tool to lift the battery up and out of its housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tasfia Hassan
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 446
