Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four 1.2mm screws in each corner.
Use the suction cup and plastic opening tool to pry the screen from the body.
Gently pry the battery up at these three spots, and disconnect the power cables attached.
You can then fold the battery back like so, and that will give you access to the screw.
Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
Once the screw and the black plastic backing are removed the daughterboard pulls right out.
In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
Één andere persoon heeft deze handleiding voltooid.
