Ga door naar hoofdinhoud
HTC Desire 510 Touch screen Glass and/or LCD Display
Wat je nodig hebt
Video overzicht
  1. HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: stap 1, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: stap 1, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: stap 1, afbeelding 3 van 3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: stap 2, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: stap 2, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: stap 2, afbeelding 3 van 3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: stap 3, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: stap 3, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: stap 3, afbeelding 3 van 3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: stap 4, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: stap 4, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: stap 4, afbeelding 3 van 3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: stap 5, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: stap 5, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: stap 5, afbeelding 3 van 3
    • Put a scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass. This will make the adhesive soften and the separation easier.
  6. HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: stap 6, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: stap 6, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: stap 6, afbeelding 3 van 3
    • Use a cutter and slightly lift the glass in one of the corners. When you make enough room, put a plastic tool.
    • Continue the separating with plastic tools to prevent the middle frame from scratches.
  7. HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): stap 7, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): stap 7, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): stap 7, afbeelding 3 van 3
    • The digitizer flex cable goes under the LCD display.
    • Slightly lift the display and unstuck the digitizer ribbon cable from the from the rear side of the display.
    Lifting the LCD out improperly will crack the LCD
    KURT PETERSON - Antwoord
  8. HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: stap 8, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: stap 8, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: stap 8, afbeelding 3 van 3
    • If you have a broken LCD display, use a plastic tool and remove it from the middle frame.
    • It's not glued to the frame.
  9. HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: stap 9, afbeelding 1 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: stap 9, afbeelding 2 van 3 HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: stap 9, afbeelding 3 van 3
    • Install a new adhesive tape on the digitizer glass.
    • First put the touch screen flex cable in the right hole and then install the LCD Display.
  10. HTC Desire 510 Touch screen Glass and/or LCD Display, REASSEMBLING: stap 10, afbeelding 1 van 2 HTC Desire 510 Touch screen Glass and/or LCD Display, REASSEMBLING: stap 10, afbeelding 2 van 2
    • Now is time to reassemble the phone.
    • That's all.
    • Did you do it successfully?
Conclusie
10 andere personen hebben deze handleiding voltooid.
ZFix
191.308 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
3 opmerkingen
thanks for this mate, super helpful
kommer - Antwoord
I did exactly this and when I turn on my phone, the digitizer recognizes touches for a few milliseconds (buggy touches) when I touch it then it stops recognizing touches. What did I do wrong?
Generic Email - Antwoord
hello i want to buy HTC desire 510 Screen because my htc mobile Touch is not working. i want to buy. plz tell me to am i buy .
imran Ali Gaming - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 15,422
