Ga door naar hoofdinhoud
HTC Desire 310 Micro USB Port Replacement
Wat je nodig hebt
    • The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
Conclusie
Alex Sander
38.237 Reputatie
202 handleidingen geschreven
4 opmerkingen
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Keith Weisberger - Antwoord
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Alex Sander -
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
It would be nice if you had explained what you were doing during the removal. What was that goo you put on it and how did it work to remove the old part?
andrew - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 721
