Ga door naar hoofdinhoud
HTC Amaze Loud Speaker Replacement
Wat je nodig hebt
  1. HTC Amaze Loud Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 HTC Amaze Loud Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Loud Speaker Replacement: stap 2, afbeelding 1 van 1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: stap 3, afbeelding 1 van 3 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: stap 3, afbeelding 2 van 3 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: stap 3, afbeelding 3 van 3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Loud Speaker Replacement: stap 4, afbeelding 1 van 3 HTC Amaze Loud Speaker Replacement: stap 4, afbeelding 2 van 3 HTC Amaze Loud Speaker Replacement: stap 4, afbeelding 3 van 3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Loud Speaker Replacement: stap 5, afbeelding 1 van 2 HTC Amaze Loud Speaker Replacement: stap 5, afbeelding 2 van 2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
  6. HTC Amaze Loud Speaker Replacement, Loud Speaker: stap 6, afbeelding 1 van 3 HTC Amaze Loud Speaker Replacement, Loud Speaker: stap 6, afbeelding 2 van 3 HTC Amaze Loud Speaker Replacement, Loud Speaker: stap 6, afbeelding 3 van 3
    • Turn the back panel over to access its interior, and locate the loudspeaker marked in the picture.
    • Remove it by gently pulling with the precision tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Akshat Shah
368 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-3, Eyestone Fall 2016 Lid van USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 126
