Ga door naar hoofdinhoud
HP w2216h Speaker Replacement
Wat je nodig hebt
  1. HP w2216h Speaker Replacement, Screen: stap 1, afbeelding 1 van 1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Speaker Replacement: stap 2, afbeelding 1 van 2 HP w2216h Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Speaker Replacement: stap 3, afbeelding 1 van 3 HP w2216h Speaker Replacement: stap 3, afbeelding 2 van 3 HP w2216h Speaker Replacement: stap 3, afbeelding 3 van 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Speaker Replacement: stap 4, afbeelding 1 van 3 HP w2216h Speaker Replacement: stap 4, afbeelding 2 van 3 HP w2216h Speaker Replacement: stap 4, afbeelding 3 van 3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Speaker Replacement: stap 5, afbeelding 1 van 2 HP w2216h Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Speaker Replacement: stap 6, afbeelding 1 van 3 HP w2216h Speaker Replacement: stap 6, afbeelding 2 van 3 HP w2216h Speaker Replacement: stap 6, afbeelding 3 van 3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Speaker Replacement: stap 7, afbeelding 1 van 3 HP w2216h Speaker Replacement: stap 7, afbeelding 2 van 3 HP w2216h Speaker Replacement: stap 7, afbeelding 3 van 3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Speaker Replacement, Speakers: stap 8, afbeelding 1 van 1
    • Remove the tape holding each speakers wire to the screen assembly.
  9. HP w2216h Speaker Replacement: stap 9, afbeelding 1 van 2 HP w2216h Speaker Replacement: stap 9, afbeelding 2 van 2
    • Remove the two 8mm Philips #000 head screws on each speaker.
  10. HP w2216h Speaker Replacement: stap 10, afbeelding 1 van 2 HP w2216h Speaker Replacement: stap 10, afbeelding 2 van 2
    • Remove the speakers by lifting them vertically from the screen assembly.
  11. HP w2216h Speaker Replacement: stap 11, afbeelding 1 van 1
    • Remove the cables that connects the speakers to the signal output board.
Conclusie
Patrick Aucoin
221 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-1, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 310
