Ga door naar hoofdinhoud
HP w2216h Power Button Replacement
Wat je nodig hebt
  1. HP w2216h Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 HP w2216h Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 HP w2216h Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: stap 2, afbeelding 1 van 1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
Conclusie
Sadeq Taha
219 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-1, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 610
