Ga door naar hoofdinhoud
HP rp5700 Power Supply Replacement
  1. HP rp5700 Power Supply Replacement, Cover Removal: stap 1, afbeelding 1 van 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Power Supply Replacement: stap 2, afbeelding 1 van 2 HP rp5700 Power Supply Replacement: stap 2, afbeelding 2 van 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Power Supply Replacement: stap 3, afbeelding 1 van 3 HP rp5700 Power Supply Replacement: stap 3, afbeelding 2 van 3 HP rp5700 Power Supply Replacement: stap 3, afbeelding 3 van 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Power Supply Replacement, Optical Disk Drive (CD Drive): stap 4, afbeelding 1 van 2 HP rp5700 Power Supply Replacement, Optical Disk Drive (CD Drive): stap 4, afbeelding 2 van 2
    • Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
  5. HP rp5700 Power Supply Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the power supply cord and the SATA cord using your hands to pull them out.
  6. HP rp5700 Power Supply Replacement: stap 6, afbeelding 1 van 2 HP rp5700 Power Supply Replacement: stap 6, afbeelding 2 van 2
    • Using your left index finger, lift the upper green tab found on the left side of the green piece.
    • Using your opposite hand, use your fingers to push the back of the drive forward and slide it out away from the desktop.
  7. HP rp5700 Power Supply Replacement: stap 7, afbeelding 1 van 2 HP rp5700 Power Supply Replacement: stap 7, afbeelding 2 van 2
    • Grasp the optical drive with your right or left hand and pull the drive out towards you.
    • It will help if you lay the device flat in order to remove the drive.
  8. HP rp5700 Power Supply Replacement, Power Supply: stap 8, afbeelding 1 van 3 HP rp5700 Power Supply Replacement, Power Supply: stap 8, afbeelding 2 van 3 HP rp5700 Power Supply Replacement, Power Supply: stap 8, afbeelding 3 van 3
    • Using your right index finger, press the tab with the green sticker located underneath the power supply.
    • While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
    • You lifted the optical drive by grasping it with the opposite hand while pressing the tab and pulling it outward way from the center of the device.
  9. HP rp5700 Power Supply Replacement: stap 9, afbeelding 1 van 1
    • Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
    • Repeat the same process to remove the internal card power cable.
    • This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
    • Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
  10. HP rp5700 Power Supply Replacement: stap 10, afbeelding 1 van 2 HP rp5700 Power Supply Replacement: stap 10, afbeelding 2 van 2
    • Continue to rotate the power supply to a 90 degree angle pointing upward.
    • Gripping the power supply with your hand, lift the power supply up to remove from the desktop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Alyssa Briones
1.699 Reputatie
9 handleidingen geschreven
Cal Poly, Team 6-23, Maness Winter 2014 Lid van Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Leden
Één opmerking
Thank you so very much for this manual! Very clear and easy to understand! Keep up the good work! Much appreciated!
jan 2332 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 2,960
