Inleiding
The extra internal cards included in this desktop are a COMs port card and a phone line card. These cards can vary in different computers. The extra internal cards are an addition to provide ports on for the computer that are not available on the motherboard.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
Using your right index finger, press the tab with the green sticker located underneath the power supply.
While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
Repeat the same process to remove the internal card power cable.
This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
Pull out the tab with the green sticker using your index finger.
6 andere personen hebben deze handleiding voltooid.
