Ga door naar hoofdinhoud
HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: stap 1, afbeelding 1 van 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: stap 2, afbeelding 1 van 2 HP rp5700 Cover Removal Replacement: stap 2, afbeelding 2 van 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: stap 3, afbeelding 1 van 3 HP rp5700 Cover Removal Replacement: stap 3, afbeelding 2 van 3 HP rp5700 Cover Removal Replacement: stap 3, afbeelding 3 van 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Alyssa Briones
1.660 Reputatie
9 handleidingen geschreven
Cal Poly, Team 6-23, Maness Winter 2014 Lid van Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 110
Altijd: 20,811
