Ga door naar hoofdinhoud
HP iPAQ H2200 LCD Screen Replacement
Wat je nodig hebt
  1. HP iPAQ H2200 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 LCD Screen Replacement: stap 2, afbeelding 1 van 2 HP iPAQ H2200 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 LCD Screen Replacement, Main Board: stap 3, afbeelding 1 van 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 LCD Screen Replacement: stap 6, afbeelding 1 van 3 HP iPAQ H2200 LCD Screen Replacement: stap 6, afbeelding 2 van 3 HP iPAQ H2200 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 LCD Screen Replacement: stap 7, afbeelding 1 van 2 HP iPAQ H2200 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 LCD Screen Replacement, LCD Screen: stap 12, afbeelding 1 van 1
    • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  13. HP iPAQ H2200 LCD Screen Replacement: stap 13, afbeelding 1 van 2 HP iPAQ H2200 LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • Press on side tabs to loosen and remove the LCD screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Andrews
209 Reputatie
5 handleidingen geschreven
Cal Poly, Team 4-12, Forte Winter 2010 Lid van Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 4,002
