Inleiding
If your wifi isn't working, it might just be a loose connection to your wireless card. Follow this guide to replace your wireless card.
  1. Ensure your computer is shut down.
    • Ensure your computer is shut down.
    • Removing the battery while the laptop is still on may corrupt your files.
    • Remove any power adapters and cords connected to the laptop body.
    • Turn the computer over so the bottom is facing up.
    • These pictures show no battery, but your battery should still be in your computer at this point.
  2. The battery release is below the bottom right corner of the battery bay.
    • The battery release is below the bottom right corner of the battery bay.
    • Slide the switch to the right until the release clicks.
  3. Remove the battery.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  4. Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver. Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. Remove the plastic hard drive cover.
    • Remove the plastic hard drive cover.
  7. Pull up on the two plastic flaps on the hard drive enclosure to remove it. Pull up on the two plastic flaps on the hard drive enclosure to remove it.
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  8. Gently lift the ribbon cable away from the hard drive enclosure to free the drive. Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  9. Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver. Slide the hard drive out of the enclosure to complete the removal process.
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  10. Locate the wireless card and the two wires attached to it.
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  11. Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver. Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  12. Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot. The card is now free from your computer.
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cory Mayer
846 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-15, Regan Spring 2014 Lid van Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Leden
10 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 4
Altijd: 630
