Ga door naar hoofdinhoud
HP dv5-1125nr RAM Replacement
Wat je nodig hebt
  1. HP dv5-1125nr RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr RAM Replacement: stap 4, afbeelding 1 van 2 HP dv5-1125nr RAM Replacement: stap 4, afbeelding 2 van 2
    • Remove the RAM cover to reveal the module's underneath.
  5. HP dv5-1125nr RAM Replacement: stap 5, afbeelding 1 van 3 HP dv5-1125nr RAM Replacement: stap 5, afbeelding 2 van 3 HP dv5-1125nr RAM Replacement: stap 5, afbeelding 3 van 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nick Loey
1.676 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-15, Regan Spring 2014 Lid van Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 971
