Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the switch to the left until the release clicks.
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Pull up on the two plastic flaps on the hard drive enclosure to remove it.
Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
Slide the hard drive out of the enclosure to complete the removal process.
3 andere personen hebben deze handleiding voltooid.
