Inleiding
Replacing the LCD display is a more costly task, but it is certainly not too difficult.
Wat je nodig hebt
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
12 andere personen hebben deze handleiding voltooid.
