Ga door naar hoofdinhoud
HP dv5-1125nr Disk Drive Replacement
Wat je nodig hebt
  1. HP dv5-1125nr Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: stap 3, afbeelding 1 van 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: stap 3, afbeelding 2 van 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: stap 4, afbeelding 1 van 3 HP dv5-1125nr Disk Drive Replacement: stap 4, afbeelding 2 van 3 HP dv5-1125nr Disk Drive Replacement: stap 4, afbeelding 3 van 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Conclusie
Nick Loey
1.676 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-15, Regan Spring 2014 Lid van Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 733
