Inleiding
The CMOS battery maintains the computer's startup settings as well as its internal clock. If your computer notifies you about changing this battery, it is best to do so immediately. Use this guide if you need to replace the CMOS battery in your HP dv5-1125nr.
Wat je nodig hebt
Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
Locate the CR2032 watch battery
Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
10 andere personen hebben deze handleiding voltooid.
