Ga door naar hoofdinhoud
HP dv5-1125nr Battery Replacement
Wat je nodig hebt
  1. HP dv5-1125nr Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
Conclusie
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 andere personen hebben deze handleiding voltooid.
Nick Loey
1.688 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-15, Regan Spring 2014 Lid van Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Leden
10 handleidingen geschreven
2 opmerkingen
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Antwoord
what is your return policy?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,197
