Inleiding
If your HP Zbook is overheating, or getting excessively hot. It may help to clean the fan and heatsink assembly. This is the step by step guide to help you clean the heatsink to your HP ZBook 15u G2.
Wat je nodig hebt
Turn the HP Zbook over and flip the switch at the top so the red part is visible.
Use a torx 8 screwdriver to remove the 11 M2.5x5mm torx screws labeled M2.5x5.
Use a pair of tweezers to remove the rubber feet at the edges and corners of the laptop to reveal the other 8 torx screws and remove them as well
Één andere persoon heeft deze handleiding voltooid.
