Wat je nodig hebt
Find the bottom panel locking mechanism
Move the switch to the right to unlock and slide it in a downwards fashion
Slide the battery latches to the right to loosen the battery
Remove the battery and place it to the side
Unscrew the three keyboard screws on the bottom
While placing the laptop on it's side, push through the hole to release the keyboard
Once the latch releases, flip over the laptop and disconnect the three connectors as well
Place the keyboard to the side and flip the laptop over again
Remove these screws with a T8 screwdriver
Remove these screws with a philips screwdriver
Once they are removed, carefully lift up the bottom case
Unscrew SSD screw and slide the SSD out
Remove these screws and place the LCD connector cover to the side
Disconnect all of the motherboard connectors
Unscrew all of the screws on the fans (Keep in mind the screw don't come all of the way out)
Make sure to disconnect the fan connectors before removing it
Unscrew the motherboard screws
Make sure the SD card holder has been removed
Remove the motherboard and place it to the side
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
3 andere personen hebben deze handleiding voltooid.
4 opmerkingen
My keyboard isn't work how i can remove it and clean it
Thank you
Thank ypu
