Ga door naar hoofdinhoud
HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: stap 1, afbeelding 1 van 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: stap 2, afbeelding 1 van 2 HP Z2 Mini G3 Access Panel Replacement: stap 2, afbeelding 2 van 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: stap 3, afbeelding 1 van 2 HP Z2 Mini G3 Access Panel Replacement: stap 3, afbeelding 2 van 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 29
Altijd: 1,073
