Inleiding
This guide goes over how to replace the controller's touch pad.
If your TPC-Q044 touch pad starts failing to register motion you may want to think about replacing the component. The failure may be a result of bad connections or the deterioration of the pad. The replacement of the touch pad is not too complex. You will need the two indicated screwdrivers and a spudger to complete this task. There are no warnings or potential hazards when replacing the pad.
Wat je nodig hebt
Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
Remove the two 6mm screws at the base of the rings using a Phillips #0 screwdriver.
Release the halo wire from the connector on the circuit board.
Pull the halo ring apart from the rest of the controller.
Één andere persoon heeft deze handleiding voltooid.
