Ga door naar hoofdinhoud
HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad Replacement
Wat je nodig hebt
  1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: stap 1, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: stap 1, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: stap 1, afbeelding 3 van 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: stap 2, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: stap 2, afbeelding 2 van 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 3, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 3, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 3, afbeelding 3 van 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 4, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: stap 5, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: stap 5, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 6, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 6, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 6, afbeelding 3 van 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: stap 7, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: stap 7, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: stap 7, afbeelding 3 van 3
    • Remove the two 6mm screws at the base of the rings using a Phillips #0 screwdriver.
    • Release the halo wire from the connector on the circuit board.
    • Pull the halo ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 8, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 8, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 8, afbeelding 3 van 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 9, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 9, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: stap 9, afbeelding 3 van 3
    • Unclip one of the tabs on the underside of the touch pad.
    • Using a spudger, pop off the touch pad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Seiji Nagasawa
219 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G5, White Winter 2019 Lid van Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 808
